TwinTurbo.NET: Nissan 300ZX forum - Do you mean the rear upright? That part is identical
Subject Do you mean the rear upright? That part is identical
Posted by zgene4 on January 01, 2010 at 11:16 AM
In Reply To Is it possible to swap out a TT axle housing with a NA posted by Wright (Ca) on January 01, 2010 at 10:43 AM
Message in both NA and TT cars, but has a different bushing pressed into the two variants at the point in question. But then you need to consider the TT subframe does not have the pick-up points for the NA rear toe arms. I have seen pictures of those grafted in place.
The easier approach would be to use the SPL HICAS eliminator. It still uses the tie rod end at the upright, so I would recommend replacing that ball joint to assure as little play as possible. There's a new FAQ for that in tech.
WARNING: I lack industry backing
